Liked 320 Times in 102 Posts
I can't take it anymore.......
Panhard bar = poor man's watts link and is ONLY used to latterly locate the rear end housing under the car....... Sway bar = anti-roll bar = stabilizer bar and it is ONLY used to control body roll by applying pressure across the vehicle.....The body wants to roll but because the bar is attached to the body and the links try to twist the bar to roll.......In some types of racing the racers like to have the links adjustable to pre-load the suspension with out changing the spring rate....... Same thing with the "anti-sway bars = anti-roll bars = stabilizer bars" that bolt solidly to the lower control arms. The bar will always attempt to keep the control arms parallel and prevent body roll....
#2 | |
Liked 9 Times in 3 Posts
Mark Markow 171 ss/tb |
#3 | |
Anti roll-bar / Sway-bar controls body roll or Sway Panhard bar / Diagonal / wishbone / Watts link control lateral movement Jus sayin.....Pete |
#4 | |
Liked 19 Times in 7 Posts
![]() Ive bought, built and broke a tonne of antiroll bars and never has the rear tires hit the quarter panel. So having said that it is in no way even close to being the same as a panhard bar. Some people just buy things and bolt them on their car...these are the people who dont understand the terminology and how things work. They kind of understand because of google but thats about it. Please...i know its the off season and some poeple are stuck in their house and their choices are listen to their nagging wife or go on classracer.com. Im not looking for an aguement here this is my opinion only and im not fingering anyone out. No internet war please. As for it being legal I think its ok as long as it bolts into the car. Its better than having a cork screwing tire rubbing disaster. It is a traction device just like a stock swaybar is a traction device as well. Id be more concerned about people having adjustable control arms because I was under the impression that that was not legal. But I have seen alot of coil sprung GM's with upper adjustable control arms. And as for the original post they welded in a brace to bolt the antiroll bar in. The car is sheet metal in this area and you cannot bolt an antiroll bar to sheet metal because the floor will buckle. As for the weld rule I would want it to be a bolt on deal anyways that way you can remove it and service the unit in between races.
Tony Valerio 1968 Camaro 1700 IHRA H/CM 1701 NHRA SS/?A Last edited by CrateCamaro; 12-05-2011 at 04:07 PM. |
Liked 68 Times in 41 Posts
it's a no go Pacific Division
same question Kelly, On that is not acceptable, for Stock. Pat Cvengros Pacific Division Technical Director
1231 FS/D Drag Pak 1231 E/SA 71 Demon Kelly MacKay |
#6 | |
You are free to call it what you want. I'm not going to belittle anybody for disagreeing.
Ed Wright 4156 SS/JA |
Liked 8 Times in 5 Posts
Looks like the list of tech guys in "other divisions" who said it was okay to weld in the anti-rollbar is dwindling.
In fact can anyone name any techman who said it was okay? Probably not. |
Liked 70 Times in 29 Posts
need Travis' input.
Chris Bowman The Mountain State Mustang 1984 Mustang GT350 |
Liked 5 Times in 2 Posts
i ran a ajustable panhard bar 3 or 4 years ago was told by n.h.r.a tech to remove it and put the stock back in also run the stock sway bar never had any luck with that trick stuff gene monahan 1021 stock p.s that was at indy
Liked 276 Times in 27 Posts
My input is that Pat Cvengros nailed it with his answer. I must also say that I have only seen bolted in anti-rollbars on NHRA Stock Eliminator cars, none that were welded in...because if I had seen one I would have definitely made an issue out of it!
Looks like it might be time to reinstate my disclaimer. (Disclaimer: Opinions expressed by me on this forum are exactly that, my opinions.) |
