#101 | |
I remember one year Scott Pearson could only afford to race two national events. He won them both. True he races SS/JA but there are many Stock racers like yourself that can't afford to attend many races. Sure would suck if you broke a rocker in a final round! Even first round breakage would cost you a lot of money.
Jeff Lee 7494 D/S '70 AMX |
#102 | |
Liked 1,869 Times in 422 Posts
![]() How many Division 2 races did you and Brenda skip this year Bill? We didn't make the tour this year, we'll be back next year. We have never broken a rocker arm, not in 6 years, although this year was real short. We've broken one 7/16" rocker stud, the poly lock killed the entire engine, including the block. We have only run near 500 passes on one set of rockers, and maybe 300 passes on the other set. No, we ain't as fast as some, but we haven't lost too many heads up races, we've got 2-3 class wins, and we usually go a few rounds fairly often. It may not be a rocket, but it ain't a slug, either.
Alan Roehrich 212A G/S Last edited by Alan Roehrich; 11-05-2011 at 09:26 PM. |
#103 |
Liked 320 Times in 102 Posts
How about the shaft type rocker guys..................
Jesel or T&D...... Take your pick No potential performance gain.......Give me a break Bob
#104 |
Liked 279 Times in 68 Posts
It's my understanding that the shaft type rockers are not legal for stock.
Greg Hill 4171 STK |
#105 |
so who makes a roller rocker that is shaftless?
Bub Whitaker |
#106 |
Liked 282 Times in 103 Posts
#107 |
Stud mounted rockers are what I was told and that jessel or t&d rockers are not legal. I think you all know what i meant.
#108 |
Liked 3 Times in 1 Post
So now, does it have to be a certain mfg or is any mfg legal, for the stud mount rocker?
Woodro Josey 2002 STK |
#109 |
News flash !! Some engine's come with a shaft from the start ! Some Ford
FE and some GM and Dodge and the list goes on . |
#110 | |
I'm a Chevy guy... pre 73 that is. No shafts there. However, to my knowledge, don't most Mopars of that earlier era, have shaft rockers ? I'm sure it's safe to assume that the new rule will at least madate that the engine has to possess the original rocker configuration. Does that mean that the shaft-rocker engines will have an advantage ? perhaps a little That's the way it is.
Aubrey N Bruneau 6409 C/S 62 BelAir sport coupe, 409 HP 409 Last edited by Aubrey N Bruneau; 11-06-2011 at 03:49 PM. |
