Old 10-30-2011, 04:12 PM   #1
Adger Smith
Liked 880 Times in 311 Posts
Default Re: fuel pressure changes...
Quote"changing to other parts might change things but not correct the original problem. and that serves no purpose.
thanks for the suggestions however.
rod in AZ" End Quote
Rod,
What he was trying to tell you was those two areas of that type fuel pump could be a problem. He wasn't trying to just have you throw a parts change at it. You might have just thought you weren't having problems before or you have picked up your program to a point where the fuel delivery "IS" a problem.
1. The screens restrict flow volume and can cause air to get mixed with the fuel. Air plays heck with regulators, Needle/Seats & emulsion tubes in the carb.
2. The pump pressure needs to be higher(with Moroso spring) because when you are leaving the line or pulling a gear change the fuel in the line sees more negative g forces and the pump needs to push harder to get the fuel to flow forward to the regulator. This could be your real problem. You have to think of the fuel in the line going forward from the rear to the front as a solid and understand how G forces apply to it. The pump needs to be putting out at least 14-18 lbs (some will say more) to keep the fuel going forward to the regulator in a real hard running car.
If you suspect the switch or electical is a problem just wire in your digital multi meter to the pump and monitor the voltage to the pump during a run.
Don't be too quick to dismiss the ideas or suggestions of someone with many years of experience.
Adger Smith (Former SS)
Old 10-31-2011, 11:22 PM   #2
rod
Liked 20 Times in 15 Posts
lew and adger. i was a bit quick, sorry. i need to change my thinking
rod in AZ
rod is offline   Reply With Quote
Old 11-01-2011, 12:12 AM   #3
Adger Smith
It was Dick, too (FED)
Your welcome.
Hope you can pick up your ride a little... :~)
