Liked 10 Times in 10 Posts
Mr. X,,,
Todays Stock Class,,,,,,,,,,,,,,,,,,,not Stock,,,,,, Not sure what it should be called,,,,,,,, Maybe,,,,,,, Modified Stock,,,,,,,,or 'Trick Stock',,,,,,, ![]() Remember the days when you could only use factory steel wheels on the car,,,,,,,,,and if you put on mag wheels, they had to weigh at least the same weight as the factory steel units. pc Last edited by Paul Ceasrine; 10-26-2011 at 08:49 PM. |
#2 | |
Banned
Liked 235 Times in 110 Posts
How about "FUNNY STOCK" ! |
Mr X.
Funny Stock,,,,,,,,,,,,,,,,,almost,,,,,,, How about,,,,,,,,,,,'HILARIOUS STOCK',,,,,,,,,, ![]() hilarious;.......'extremely funny' |
Performance Results;
Car Life Magazine, April 1966 Editor; Allan Girdler Test Location; Carlsbad Raceway Dragstrip Transmission; C-6 Automatic Gears; 3.25 Tires; 7.75 x 14" Results; 15.20 @ 90 MPH Note: The Comet Cyclone GT came equipped with fabricated headers from the Southern California Mercury Dealership. Headers; 1 5/8" primary tubes, 32" length, 10" collectors, with 3" openings. Note: The collector caps were removed, and the test was performed with open headers. Note: Shift points; 1st to 2nd (4800 RPM), 2nd to 3rd (4600 RPM). ---------------------------------------------------------------------------------------------------------------------------------------------------------------------------- Hot Rod Magazine, October 1965 Test Location; Irwindale Raceway Technical Editor; Jim McFarland Transmission; 4-Speed, Top-Loader, Close-Ratio (2.32 / 1.69 / 1.29 / 1.00) Gears; 3.50 Tires; 7.00" M & H Cheater Slicks on 14" rims Results; 14.40 @ 99 MPH Last edited by Paul Ceasrine; 10-27-2011 at 06:55 PM. |
Car Craft Magazine, March 1966 Writer; Roger Huntington Test Location; Detroit Dragway Transmission; 4-Speed, Top-Loader, Wide-Ratio (2.78 / 1.93 / 1.36 / 1.00) Gears; 3.25 Tires; 7.75 x 14" Results; 14.68 @ 95.5 MPH Note: The car was prepared and tested by the 'Gass Hoppers Hot Rod Club', out of Morton Grove, Illinois. Note: The car had a performance tune-up, including a spark-advance and a colder set of spark-plugs. ------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- Performance Results; Super Stock & Drag Illustrated, April 1966 Contributor; Tom McCahill Test Location; Daytona International Speedway Transmission; 4-Speed, Top-Loader, Wide-Ratio (2.78 / 1.93 / 1.36 / 1.00) Gears; 3.50 Tires; 7.75 x 14" Results; 14.40 @ 96 MPH Last edited by Paul Ceasrine; 10-28-2011 at 10:09 AM. |
Cars Magazine, March 1966 Writer; Martyn Schorr Test Location; New England Dragway Transmission; 4-Speed, Top-Loader, Close-Ratio (2.32 / 1.69 / 1.29 / 1.00) Gears; 3.90 Tires; 7.75 x 14" Firestone 500's Results; 14.95 @ 98 MPH Note: This Comet Cyclone GT was the 'Press Test Car'. It had 8000 miles on it, mostly hard-driving testing. Note; New Firestone 500 tires were installed on the car before testing. Note: The car (based and registered in Michigan) was delivered to Cars Magazine in New York. The car was taken to the famous performance shop 'Pacers Auto', in Oceanside, Long Island, New York, for a complete tune-up before the performance test. Note; The test crew then drove the car 500 miles, to the testing strip, New England Dragway in Epping, New Hampshire. Last edited by Paul Ceasrine; 11-11-2011 at 12:21 PM. |
Liked 21 Times in 9 Posts
Wow 7.75x14 inh tires with a 390 and 4spd. I had forgotten how
small thje rubber was back then. What would have that Comet gone with todays hi performance tire and wheel package? |
