Old 10-02-2011, 05:58 PM   #1
Bob Lasko
Bob Lasko's Avatar
Liked 185 Times in 54 Posts
Question What Brake Controler????
What brake controller would you recommend???? I have a 2008 chevy 2500, and tow a 28 foot enclodes trailer.
Thanks,
Bob Lasko
Bob Lasko is online now   Reply With Quote
Old 10-02-2011, 06:04 PM   #2
Bob Bender
Bob Bender's Avatar
Liked 459 Times in 90 Posts
Default Re: What Brake Controler????
I got mine at Wal-Mart 5 years ago and still woorking.
Bob Bender 144 O/SA
Old 10-02-2011, 06:26 PM   #3
jim powers
jim powers's Avatar
Liked 13 Times in 10 Posts
tekonsha prodigy 2 ,easy to install and adjust
jim powers is offline   Reply With Quote
Old 10-02-2011, 06:28 PM   #4
Tom Moock
Liked 10 Times in 6 Posts
Bob, 2008 Chevy 2500 should have controller built in dash from factory, if it has trailer towing package.Tom
Tom Moock 5704 STK
Tom Moock is offline   Reply With Quote
Old 10-02-2011, 06:36 PM   #5
Bob Lasko
Bob Lasko's Avatar
Cool Re: What Brake Controler????
This truck, I did not orderit with the controller,duh.
Old 10-02-2011, 07:09 PM   #6
Greg Barsamian
Liked 419 Times in 96 Posts
X2 on the Tekonsha Prodigy ll
Old 10-03-2011, 12:06 AM   #7
Keith 944
Keith 944's Avatar
Liked 1,877 Times in 577 Posts
i have one i just took out of my motor home (prodigy) i will sell very reasonable if interested.
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 10-04-2011, 08:29 PM   #8
sc180b
Thanks,
Bob Lasko
There are a lot of good controllers on the market.
The most important part of the electric brake system is the the magnet and inside magnet surface of the brake drum. The magnet surface in the brake drum should be a flat surface with no grooves or ridges. Machining this surface on a used drum often puts it too far away from the magnet to work properly. It worries me when I hear the brakes are making a humming sound, this indicates the magnets are not properly attaching themselves to the inside of the brake drum.
There is a hydraulic disc brake system on the market to replace the existing electric brake system. This system works off the same brake controller that most electric brake system use. The hydraulic disc brake system can be retrofitted to all existing axles. The stopping is ability is much safer.
sc180b is offline   Reply With Quote
Old 10-05-2011, 12:53 PM   #9
FrankM
FrankM's Avatar
Liked 3 Times in 2 Posts
I have a Prodigy and would never buy another one. I have a 24' enclosed and a 5th wheel camper I use it on and find it very erratic. It might be related to the Allison tranny braking but the inertia sensor is sensitive. It does adjust easily though, which is the one good thing when alternating trailers.
FrankM is offline   Reply With Quote
Old 10-06-2011, 10:30 PM   #10
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Thumbs up Re: What Brake Controler????
Put one on the truck and in the RV, then I read the directions that said they have a bracket that you can take it out of one and plug into the other like a GPS ! I didn't need to buy two of them. Oh well they are the best out there right now and I can't believe how much smoother the braking is now! Jim
