Old 10-02-2011, 03:48 PM   #1
rod
Liked 20 Times in 15 Posts
Default msd dist problem.
well i now have another ing. problem
i just bought an early design msd chevy dist. this is used but very little. it was just out of a running engine. with my point dist, the engine starts like a stock engine [that is, it starts quick], and idles at 1100. i dropped in the electronic msd and dry timed it. it takes a lot of cranking to catch. and will not idle at less than 1900, and even then it labors. i set the total timing at 45.
i reversed the leads to the msd 6 [on a chance] reset the total, starts the same [hard] and still idles the same-high.
R&R the point dist, starts quick and idles at 1100.
ideas?
thanks rod in AZ
rod is offline   Reply With Quote
Old 10-02-2011, 05:58 PM   #2
pmrphil
Liked 347 Times in 151 Posts
Default Re: msd dist problem.
Are you also using the points dist. with the MSD? Using the white wire with points, then using the plug-in for the MSD dist? Capping off the white wire? Are both distributors locked out timing? BTW, why so much total?
Phil Molski
PMR Performance
S/C 1623
Old 10-02-2011, 06:54 PM   #3
rod
all this is just too much trouble. the msd dist is going in the scape pile!
rod in AZ
Old 10-03-2011, 09:23 AM   #4
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
ideas?
yes, the mechanical advance isn't setup correctly for your engine and can be easily fixed.
