Old 09-08-2011, 05:45 PM   #1
RPinoski1
Default Re: 327 vs 283
I see it now...I wasn't looking down the sheet far enough.
"I've never seen a Hearse with a Luggage Rack, You Can't Take it With You" Mike Ness
RPinoski1 is offline   Reply With Quote
Old 09-08-2011, 06:44 PM   #2
67chevygary
Has anyone flow or tack tested the different powerpack heads?
67chevygary is offline   Reply With Quote
Old 09-08-2011, 07:00 PM   #3
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Think the 520's are the ones you want..
On the fronts of the heads they have a Rectangle with a Small tiangle on top of it.
If it is just a Rectangle they are they earlier 61 heads.
Damn this was a long time ago ..1973 ran a 64 Impala SS M/S
With a mucie m20 tranny..and pumpkin rear.
Choice of Carter WCFB or Rochester4bbl which were 450 cfm at best.
But were really responsive.
I am CarbonDating myself...
D
Old 09-08-2011, 09:14 PM   #4
67chevygary
I started a thread about a month ago about what I need to get my '57-150 ready for class racing in either n/s or m/sa. I've talked to a few people about which parts to aquire. but still looking for as much input as I can get. so far i think i've got the right block-the correct single 4 barrell-but need input on heads-intake-rear end & trans-still looking for a correct 2x4 set-up. all input is much appreciated as I've forgotten way more than I ever knew.
Old 09-09-2011, 11:09 AM   #5
Dan Fahey
Dan Fahey's Avatar
Find a 55-57 Chevy Forum..You should be able anything you want !!
Suggest sending the carbs to Val Headworth and have them fix them up right!
For camshafts recommend Bullet Cams.
They have many of the experienced Cam Makers from Lunati, Comp, Crane and others.
That also know your combination and history on making those cars run.
D
Old 09-10-2011, 12:28 AM   #6
Jeff Lee
Jeff Lee's Avatar
As a VERY BASIC rule of thumb, 1 HP per CID, all else being equal. In this case, your talking 44 cubic inches or 44 HP. That's "pretty close" to what Brad said; 2 1/2 tenths. And he has real world experience. That just allows you to do some quick calculations to determine if the CID increase cancells out the HP or weight increase. And of course you should easily make 1.25+ HP per CID for any class engine.
Jeff Lee 7494 D/S '70 AMX
