Old 08-12-2011, 02:29 PM   #1
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
Default A/C Question
I have a 2002 Chevy 1500HD crew cab. The a/c works fine going down the highway. If you are sitting still(at a light etc) the vents put out warm air then when you start driving its fine again. Any ideas?
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 08-12-2011, 10:11 PM   #2
Jim Blankenship
Default Re: A/C Question
one or both problems
just low enough to cool driving and/or the cooling fan isn't working ,
some cars/trucks have a fan on the coil out in front.
don't get one of the cheap fill kits freon can be nasty to your body if a hose burst
a tech with gauges can tell the problem real quick .
ps with it idling with ac on see if the ac comp clutch is cycling both problems stated above can cause it to . if no elec. fans and cooling fan on water pump is pulling air thru the red. it prob is just low gauges tell fast jim
Jim Blankenship 3086 STK
Jim Blankenship is offline   Reply With Quote
Old 08-15-2011, 09:27 AM   #3
Jim Cimarolli
Liked 166 Times in 46 Posts
Smile Re: A/C Question
Might also check to see if the outside of the radiator is clean of debris.
Jim Cimarolli is offline   Reply With Quote
Old 08-15-2011, 04:38 PM   #4
Dennis P Chapman
Liked 53 Times in 25 Posts
I had the same problem a few years ago the clutch fan was bad. Replaced it never had it happen again.
Dennis P Chapman 1904 STK
Dennis P Chapman is online now   Reply With Quote
Old 08-15-2011, 05:59 PM   #5
Ed Carpenter
Thanks for the input guys.
Ed Carpenter
Old 08-18-2011, 12:26 PM   #6
Jim B
Quick and easy: Put a floor fan in front of the grille with the A/C on at idle. If insufficient air flow through the condenser is the culprit you'll see the vent discharge temperature drop real quick when you turn the floor fan on. I've had this condition caused by GM clutch fans that absolutely did not feel bad or slipping by hand.
Jim B is offline   Reply With Quote
Old 09-08-2011, 01:57 PM   #7
njk53
What are the vent discharge temperatures at idle? Going down the road?
Your truck has a viscous type fan clutch that really doesn't move a lot of air through your heat exchangers like an electric fan would. So, your discharge temps will be high @ idle. This was always a problem with a viscous type clutch. Any way, make sure the fan clutch is good. If it is good, make sure you have the correct amount of refrigerant in the system. Too much refrigerant and/or PAG oil will degrade A/C performance.
Nelson Kowal
Stock 345
