I guess what I was getting at is can later model trans & rear ends be legally used with a ,57?
Another thing-what is the 'captain rule"?
Liked 20 Times in 12 Posts
The captain rule as I understand it, all 1958? to 1963 sbc that came with the turbo glide can use the T200 or T350. But, with the 57, the 220hp is the best combo. We run a 3sp manual in SS and it is the one hold up (Now we can run a 4spd) but not in stock. I would run the powerglide combo with a 12bolt. You will have more cars to run in N/SA vs N/S. With that said the 3sp manual with a Jerico (Got one) is a good reliable combo. So you just make a choice on what you rather run? Two pedals or three?
Robert P.S. VERY COOL CAR! |
Banned
Liked 235 Times in 110 Posts
Liked 889 Times in 239 Posts
66 Impalla rear will fit the 150 nicely,its within 3/8" of stock width.
Just weld on the spring pads. I've got a '57 150 in the shop right now with this rear, altho it's got a LS 3 Vette engine in front of it! Just keep in mind 12 bolt gear ratio availability for those little motors. 10 bolt rears have a better availability of very low ratios, and will certainly hold up behind a 265 or 283.
Here's a new twist - since they allow a Metric 200 via the "Jack McCarthy" rule should they allow a 4 speed in this car because it came with a 3 speed with overdrive ?
Jack Matyas 1547 FS/C 2015 Camaro COPO # 62- 2012 Camaro Convertible COPO |
Jack; that's why I love this site-somebody always thinkin'- I'll talk to Cal method more about this idea at next weeks divisional. thanks everyone for all their input!
