Old 07-11-2011, 08:29 AM   #1
tj310
Default Re: Computer Tune?
Is this a OEM computer ? I also have my wife's 95 Z in the shop. Ran great for the first 3 weeks. ..Thanx Trevor
Old 07-11-2011, 01:09 PM   #2
Ed Wright
Ed Wright's Avatar
If it ran OK for a while, something is wrong with the car. The computer calibration can not change. If it has an O2 sensor feed back problem, causing the computer to make some wrong corrections (learned something wrong) just pull the PCM Batt fuse, cycle the key on then off, plug the fuse back in, start it up and it will go back to running well again. If not, something has gone wrong with the car. Only way the tuning can change would be if the eeprom inside is failing, you would then get a memory error DTC, a Service Engine Soon light on the dash, and it would run in Limp Home Mode. The computer checksums it's self everytime the key is turned on. Any change at all to the calibration and you get that code, light, and very poor performance.
Ed Wright 4156 SS/JA
Old 07-11-2011, 11:31 PM   #3
TinSoldier 3215
Liked 6 Times in 5 Posts
ED, This is a street/ racecar it haves a comp cam and head work and a new msd disbutor motor was freshing up and car haves seat 2/1/2 years before started up, He thinks the computer needs tune?
TinSoldier 3215 is offline   Reply With Quote
Old 07-12-2011, 08:38 AM   #4
Ed Wright
Ed Wright's Avatar
If the computer has not been tuned, it does need it. Anytime you change anything in an EFI car the computer needs tweaked also. If I can help let me know.
Old 07-12-2011, 07:38 PM   #5
TinSoldier 3215
ED, yes the computer haves been tune!!
Old 07-12-2011, 08:20 PM   #6
Ed Wright
Ed Wright's Avatar
What's it doing wrong?
Old 07-13-2011, 02:53 AM   #7
TinSoldier 3215
Its running rich.
