#51 |
Liked 20 Times in 3 Posts
Yes sir, I stopped counting at 40k lol it was starting to hurt my feelings. My engine is getting dynoed/freshened up for BG and Indy, so hopefully in a few weeks. Great post, I knew you and Billy would be great at doing this and to be honest if I knew this could be done for 5k, I would put up the money just to show everyone it could be done. Might encourage some people to do the same on a limited budget. Great ideas.
#52 | |
Liked 8 Times in 7 Posts
don't see many 4 cyl trucks/jeeps come thru the shop.... too much altitude out here... VERY little 2wd truck, too. |
#53 | |
Liked 5,145 Times in 1,964 Posts
I seemed to only run right around the index. It kinda disappeared after some rumors surfaced about a 305 short block. I hope not, because it didn't run all that well. Anybody?
#54 | |
Liked 783 Times in 195 Posts
You mentioned something there that makes me think. We ought to do that as a project and document a blow by blow (might even Facebook or Twitter it) just to see if it can be done. Reckon we could get a magazine or website or manufacturer to fund it???? |
#55 | |
#56 | |
Liked 7,843 Times in 1,750 Posts
#57 | |
Liked 53 Times in 25 Posts
Remember the blue sundance I built had less them 2800.00 in it got a lot of parts of ebay. That car went 1.16 under old index.
Dennis P Chapman 1904 STK NHRA National Record Holder Car Owner. |
#58 |
Liked 38 Times in 17 Posts
I'd hate to tear it down but I think a 96-97 Thunderbird 4.6L might be considered a "dime rocket". Really don't think the 96-98 Mustang 4.6L 2V would be too bad either.
#59 |
Okay, bargain hunters! Ready for an off-the-wall challenge today? Today's entry for consideration is a
71-72 AMC Ambassador 304/210/180 for U/SA Much the same characteristics as the 305 2-bbl Chevy except for the funky body. When compared to the Chevy, some similarities are: Slightly bigger bore and shorter stroke. A bit more compression. Similar sized carb, though a Motorcraft rather than a Rochester. Better flowing heads. Longer intake runner; maybe beneficial for more torque. Generous camshaft. Better rod-stroke ratio (if that matters, but it sounds good). 904 Torqueflite. Adequate rear end - 8 7/8" ring gear AMC 20. Cheap pistons available. I know that a similar one was raced a few years ago, but it was a '76 station wagon which does not have as good motor pieces and could not get within 300 lbs of minimum weight. Even so, that car ran .3-.4 under. |
#60 |
Dwight, you beat me to the keyboard this morning! I wanted to do the 304 (think spoiled brat stamping his feet)!
I'm going to guess that my next one could be done within our budget but I will probably have to go to Mark for a final thumbs up. Lew Becker and I ran across one of these cars at an auction and I actually had Lew bidding on it. It was very clean and didn't go for any real money. 76 Buick Century with 2V 350/205 or put the 4V on it. It makes Q/R/T with 2V or swap intake and make O/P/Q. 1.250 Venturi 2g flows around 350 cfm, great heads, small cam, medium valves but at 205 HP it's 25 HP less than a 350 2V Chevy that does work. Only real down side that I could see is the big, heavy body that it has to go in unless it were in a Skylark for P. But it is a 6 class car with an intake change! Marky Mark, can it be under the index on our budget?
