Liked 238 Times in 113 Posts
What transmission are you running ? I have experienced something similar with three speed trannies. Sometimes at the top of 1st gear, the high gear clutch will start to drag, and the car feels like it's running out of power, but when you shift to 2nd, that drum stops spinning, and the drag goes away. There is an easy fix for this, by drilling a small vent hole in the high gear clutch drum.
