Liked 84 Times in 21 Posts
I'm looking for a good Q-jet identification site. I used a site once that all you did was plug in the carb number and it would give you all the info. Unfortunately I no longer can find that site, I'm sure I marked it as a favourite for future use but can't seem to find it now. Thanks for any help. Doug
Try, newagemetal.com
Bill Belden Retired Stock Eliminator [emailSTK1100@comcast.net[/email] |
Liked 99 Times in 60 Posts
Doug, one option, send a PM to Danny Ashley, he is a Q-jet master.
Larry Woodfin 471W |
Liked 482 Times in 159 Posts
that newagemetal site is a nice resource ... original acdelco parts lists and diagrams
Liked 460 Times in 91 Posts
web site called Carb Unlimited
Bob Bender 144 O/SA 2010-2012 National Record Holder |
I've found decoding info but what I'm looking for is a site I used some time ago that you simply entered the carb numbers and it would tell you what it came on. Very simple especially if you had a quantity of carbs to ID. Print it off and go make your tags so when you looked at that dirty old carb on the shelf you knew exactly what you had at a glance.
Try this http://www.google.ca/url?sa=t&source...sqA-QpN4CbxJiQ for identification info. It's not quite what I was looking for but does supply a good amount of info on Q-jet ID. Sorry about the long address. Doug
Sorry about that address, I just tried it from my reply and it shows holley info not Q-jet. I've been to his pdf file on Q-jet's and it is very resourceful but I can't seem to be able to copy the link. Doug
Ok. Try this http://www.club-corvette.dk/forums/c...uningPaper.doc If this doesn't work I'm just going to walk away for awhile.
Looks like I better walk away!!!!!!!
