05-08-2011, 06:36 PM | #1 |
Liked 5 Times in 3 Posts
Cam question/help
I bought a 305 out of an 81 Z-28 the cam that was in it was a Crane part # 11-41-84 grind # ssh-310-nc I can't find any info on it.....anyone know what it is?
05-08-2011, 07:06 PM | #2 |
Liked 321 Times in 101 Posts
Re: Cam question/help
Hi,
I found this on the Nasty Z28 website.... I don't know if info is correct???????????? Crane 114051 SSH-310-NC, hydraulic, rough idle, good midrange hp Intake Open-Close BTDC-ABDC 40-90 Exhaust Open-Close BBDC-ATDC 88-42 Degrees Advertised Duration Int. 310 Exh. 310 Degrees Duration @ .050 Cam Lift Int. 236 Exh. 236 Running Clearance Hot Int .000 Exh. .000 Gross Valve Lift Int. .485 Exh. .485 RPM Range min 3800 max 6800 valve float 7000 Good luck, Bob
05-08-2011, 08:11 PM | #3 |
Humm I just check lobe lift it was .314 that would make it 470 with a 1.5 rocker. Thanks for the info Bob
