Old 05-08-2011, 07:52 AM   #7
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
Default Re: AIr bag/lift system for pick up
I bought the Airlift 5000 system to replace the overload springs on my dually R20 Suburban because I needed more adjustability. Once the leafs are cranked up the ride is terrible when the trailer isn't hooked up. There are a few brackets that need to be cut from the frame for clearance so I'll be installing them later this month. They also recommend that some pressure (5 psi) be kept in the bags at all times, even when unloaded, to prevent them from chafing.
Good luck with your installation!
Lew
Lew Silverman #2070
"The Wagon Master" N/SA
