Re: Milk in valve covers
Believe me when I tell ya we tried everything--pressure tested the heads/magnafluxed the block/replaced every gasket that was even near water/sealed every bolt that was near water/checked for cracks or leaks every where even swapped out engines but still using Pennzoil and finally after talking to Glidden at the Gators when he borrowed some spark plugs from me he suggested switching brands of oil and it magically went away---seems the moisture mixes with the Pennzoil differently than it does with the other brands of oil resulting in the milky look we switched to Valvoline then and never had a problem like that again
