Liked 138 Times in 51 Posts
I've found that some OEM style mini-starters need a little clearancing. The area on the block has been around a hole that is in the bottom of the bellhousing area. I believe a spot there is usually machined at an angle, but for some reason, some starters still hit. Maybe it's something with slightly different starter bodies......just in case you run into that.
