Old 04-22-2011, 03:25 PM   #12
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
Default Re: Holroyd BBC Rocker Arms
I'll give my 2cents I know I will probaly regret it.
If the rules are stock rockers then I think they should be unmodified that you can see by eye.
If aftermarket was allowed then I say shaft rockers should be allowed,that way all brands should be on level playing field then, for example if it was stud mounted rule,dodges,buicks,fe's can't run studs,so then you have people fussing why can't I run shaft rockers like that dodge,buick or fe.
I think that would be fair to everyone,there are combo's that are at a disadvantage because of rockers now whether it is weaker design,non adjustable,yeah I know you can use adjustable pushrods,but that is real pain in the rear.
Personally I would like to see things stop changing.when was it 1986-1987when,cam/spring rule changed?
I like change, especially when they change it back to the way I liked it to start with.LOL
Mike Taylor 3601
