Old 04-19-2011, 07:46 PM   #21
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Thumbs down Re: Holroyd BBC Rocker Arms
If NHRA hadnt allowed the crazy valve spring pressures years ago stockers woulnt have to use this crap. its just costing you more money.
Old 04-19-2011, 08:29 PM   #22
james schaechter
Liked 1,435 Times in 299 Posts
Default Re: Holroyd BBC Rocker Arms
[QUOTE=Mark Yacavone;253760]
Originally Posted by james schaechter View Post
Mark, there were some guys welding up the pushrod sides of their rockers and no one in tech had issues with that. The rocker had to stand a lot of heat in that process. The problem seemed to be that if the rocker got too brittle, it would break anyway.
Jim, I was just wondering when it became legal to weld or customize stock rockers??
When we went to Indy in '04 with the 350 Buick, I had already split a couple of rockers at the shaft hole. I wonder how long we would have lasted in teardown if I had welded a bridge piece across the top of my rockers to strengthen them up?
Let's do a poll:
5 seconds
10 seconds
15 seconds
Mark, who knows? All I know is that there are many things out there that are in now and no one knows why.....
James Schaechter 3163 STK
Old 04-19-2011, 11:31 PM   #23
Dan Lattimore
Liked 154 Times in 37 Posts
Terry, No one knows that more than me and I hate that it has come to this. All my stump pullers still use 130 seat and 330 open, the extra rpm these spring pressures allow are no advantage to me. On the other hand if I don't play by the new rediculous rules the L88 would be left way behind.--------Danny
66W30POST
Dan Lattimore is offline   Reply With Quote
Old 04-20-2011, 01:44 AM   #24
Jeff Lee
Jeff Lee's Avatar
Those $279 Crane Gold rockers for Stock don't sound so bad against a $900 set of stamped rockers now do they?
Jeff Lee 7494 D/S '70 AMX
Old 04-20-2011, 03:49 PM   #25
mannymen
Liked 13 Times in 7 Posts
Smile Re: Holroyd BBC Rocker Arms
racear I said dark chocolate not laxative chocolate
N/A
mannymen is offline   Reply With Quote
Old 04-20-2011, 07:58 PM   #26
Bob Shaw
Liked 316 Times in 61 Posts
The rule book says rocker arms can not be modified. I asked Wesley if I could modify mine so they wouldn't split and he said "no".
Bob Shaw V/SA 515
Bob Shaw is offline   Reply With Quote
Old 04-20-2011, 10:04 PM   #27
X-TECH MAN
Banned
Cool Re: Holroyd BBC Rocker Arms
Hummmmmm, Interesting.
Old 04-20-2011, 10:08 PM   #28
X-TECH MAN
Banned
Originally Posted by Grant Eldridge View Post
The rockers Clark uses are Marine, identified by a particular marking inside the rocker. He has machined a re-inforcement that fits above the pushrod seat and is welded into place. The design is a nice fit, with an oiling hole that aligns with the hole in the rocker. I doubt you could do these yourself for the money, unless you could design them and had a cnc machine capable of making the inserts and did not count your time. I just got mine back from being upgraded, Clark is great to do business with and IMO his stuff is top notch. The Stud and adjusters he makes to use with these rockers are beautiful, sure they cost $$ but for a limited specialty product worth it....they are also legal as purchased from Clark.....
my 2 cents...
Grant Eldridge
It sounds like the difference between the west coast rule book and the east coast rule book. Is it legal to do this or not ? Travis????????
Old 04-20-2011, 10:51 PM   #29
Bub Whitaker
Yes TECH MAN... this is a load of crap... no aftermarket rocker arms...what does that mean?
Bub Whitaker
Bub Whitaker is offline   Reply With Quote
Old 04-21-2011, 08:15 AM   #30
Charley Downing
Liked 633 Times in 88 Posts
Bub,Terry just has to bit#h about something NHRA did. He has nothing better to do with his time.
Charley Downing 3548 STK
Charley Downing is offline   Reply With Quote
