Old 04-15-2011, 02:25 PM   #6
Mark Madison
Liked 32 Times in 9 Posts
Default Re: Racepak for stick cars
This works for me. Instead of mounting the fragile $80.00 sensor on the input shaft I mounted mine on the side of the case so that it reads a split collar on the cluster. The spud pictured is counterbored and tapped to accept a standard RacePak driveshaft / clutch sensor. The RacePac program is able to correct for the M/D ratio of the cluster for a direct single line readout as if the sensor was reading from the input shaft.
Mark Madison is offline   Reply With Quote
