Old 04-05-2011, 03:36 PM   #1
buzzinhalfdozen
Liked 11 Times in 8 Posts
Default Re: exhaust temp help
No arguing that Tom with properly working wide band o2's fuel management is greatly simplified. If for nothing less than the increased response time they are a worth while addition to any tuning arsenal. The biggest issue I've seen is racers searching for that "magic AFR" basically there isn't one. Joe
Joe Buchanan SS/BX 3117
Old 04-05-2011, 05:50 PM   #2
Chris Hill
Liked 244 Times in 26 Posts
Some other things for EGT from a pure theory standpoint.
Compression goes up, EGT goes down
If starting rich, leaning the A/F ratio will increase EGT, it will peak at stochiometric, then decrease as it gets leaner still
Advancing spark timing increases EGT till ????? (sorry, having a brain fart and can't remember)
EGR (including internal EGR) will decrease EGT
Detonation causes EGT to decrease? (I think this is correct)
Volumetric efficiency causes EGT to ???? (can't remember this also)
EGT trends with peak cylinder temperatures and thus NOx emmisions.
Chris Hill
Old 04-05-2011, 08:04 PM   #3
marvstrick
Liked 33 Times in 10 Posts
Question Re: exhaust temp help
engine builder said to get ried off msd timing retard . i am running 40 degrees . when looking at timing with alterator on above 4000 rpm timing keeps going.
marvstrick is offline   Reply With Quote
Old 04-06-2011, 10:16 AM   #4
Ed Wright
Ed Wright's Avatar
Ain't that the truth? Kids come in for tuning read on internet message boards that 13-1 is the magic number, and that is what they want. Heck, 13.5-1 will often make big dyno numbers, seldom goes down the track as quick. Depends on the engine and fuel of course, but there is no magic number. Mine likes mid-twelves. (Air/Fuel ratio, not EGTs)
Ed Wright 4156 SS/JA
Old 04-06-2011, 12:40 PM   #5
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 317 Times in 108 Posts
I think EGT's can be alot like dyno's numbers vary I'd say you would have to find your spot on jetting for fastest,quickest,then use that # your EGT shows to be your reference.
I've not had any in car EGT's but on engine dyno on gas around 1375 was close to best temp alky was around 1200.
I had engines where EGT would be 900-1000 move jetting,timing never get to change,so would have to jet by power&torque to find best jetting,those engines were always better than average of comparable engine I had dynoed and had wider and flatter power&torque curves. On those engines when you pull headers they would be black about 2-3'' down tube then go to nice toasty tan.
EGT thermocouples are'nt the most consistent thing,they go bad they change,you can buy thermocouple tester that checks accuracy of thermocouple.
Where you put in header tube makes a difference I think Superflow told us to go about 3'' out from head.
I think most people put probe in #5 in BBC it seems to be hot cyl on BBC.
Usaully on dyno adv.timing would drop EGT,ret. would raiseEGT.
Mike Taylor 3601
