#41 |
Liked 11 Times in 8 Posts
Ed, I'll assume from the business you're in you have a DVOM? Hook it to the power supply circuit for your MSD or FAST unit, most have a record function to record high, low and average voltage set it to 1ms record speed and make a lap. If all looks well there, hook up to your crk. sensor circuit, also record set to AC voltage and monitor, a sudden change here would indicate an issue. Hoe are your Ign. components powered/ Relay, direct from switch? I have seen relays cut on and off due to points bounce, What sample rate does you datalogger have? Sorry for all the questions, just intrigued by the problem. Joe
Joe Buchanan SS/BX 3117 |
#42 | |
I did replace those power wires to the FAST ECU and MSD box and the ignition switch Saturday. May have fixed it. Need to test again this week. I'm wearing it out chasing this down. Eight passes Friday, and accomplished nothing. I do know what it isn't. <G> Thanks, Ed
Ed Wright 4156 SS/JA |
#43 | |
Liked 502 Times in 130 Posts
Good luck Eric
Eric Merryfield 1883 STK |
#44 |
Liked 19 Times in 8 Posts
"I did replace those power wires to the FAST ECU and MSD box and the ignition switch Saturday. May have fixed it. Need to test again this week. I'm wearing it out chasing this down. Eight passes Friday, and accomplished nothing. I do know what it isn't. <G> Thanks, Ed" Did you see anything with the wires?
Joe Schweigert 751 SS |
#45 | |
Nope. I tried wiggling & tugging on the wires while it was running with no cut-off. I had those two wires running from a small fuse panel for "switched power" accessories. Now it's a double pole switch, one side powers that panel, the other side of the switch only powers the MSD box & FAST ECU directly. Had to make up new wires to do that. And that new switch. About to pull the rest of my hair out.
#46 | |
Foot braking would isolate that circuit. Good idea. Thanks, Ed
Ed Wright 4156 SS/JA Last edited by Ed Wright; 04-04-2011 at 10:23 PM. |
#47 |
Liked 880 Times in 311 Posts
Ed,
Could the 3 step be faulty and sending a charge back to the T-brake?
Adger Smith (Former SS) |
#48 |
Ed, is this thing a speed density set up, or does it have a MAF sensor?
What are you using for a distributor? I want to go back over some of this, and see what you've replaced, or bypassed. MSD box? Coil? Batteries? Crank trigger pick up? Coil wire? ECU? Transbrake switch? Master switch Ignition switch? Transbrake solenoid? Starter solenoid? Battery cables? Anything else? Have you tried looking over all of the wiring, and using wire ties or "strain relief" to keep the wires from moving anywhere? Have you tried tapping sharply on your electrical devices? I'm sure you're familiar with the old "tap test" that we all used to use checking things like the MAF years ago. Also, what was changed, or what happened, immediately prior to this problem rearing its ugly little head?
Alan Roehrich 212A G/S |
#49 |
Adger has a good thought, are you using a two or three step and if so at what RPM are the "pills"? Is one of them the same as the RPM engines dropping back to? Though I've never tried it I'd suspect even a small amount of voltage say 8-9 volts at the rev. limiter may be enough to activate it, where it would reqire full voltage to activate the trans brake. Joe
#50 |
I use the 7AL2Plus boxes. Heard too many stories about the 7AL3 stuff. I use the rotory 2 step RPM selector, but did plug a regular chip in it's place Friday. thought I had it one pass, then it did it again. It is speed density. I have tapped on everything, flexed and tugged on wires. Only thing I have not yet tested, but it's next, is the master battery cut-off. I have banged on it, and jerked on the battery cables trying to make it cut off, mis-fire, something. Right now both battery cables are on the same post. Guess I'll find out this weekend. Wanted to rent the track, but they are working on it this week. Water problem near the finish line. Been so dry here, I can't imagine where it's coming from.
