#21 |
Liked 767 Times in 212 Posts
If my memory is correct, years ago the rule book did indeed say that you needed a net if you had a cage, regardless the ET. Somewhere along the line, that was changed to the current wording.
#22 |
IF you have a window net, don't install it to tight...in case of fire it will shrink and you will not be able to release the buckles, that's bad!
#23 |
Liked 1,888 Times in 581 Posts
I have been racing my Demon for the last fifteen years plus with a full Chrome Moly Cage. It has a current chassis cert. on it and a ETI on it. I, have raced SS/JA and KA plus E/SA to G/SA.......has not had net in it since 1995 (175 Div./ Nat. Races) without an issue.
#24 |
Chassis cert don't have anything to do with the window net. (chassis only)
Danny Waters, Sr / 73 Duster "340" |
#25 |
Liked 389 Times in 168 Posts
There ya go!
Ed Wright 4156 SS/JA |
#26 |
Liked 703 Times in 206 Posts
Rulebook section 6.3 states "any car REQUIRED to have a roll cage must have a window net"
The key word is required. .....If you are quicker than 9.99 or faster than 135 mph, you need a cage, AND a window net. ....Slower than that ,you dont need the net.
#27 |
Liked 1,656 Times in 507 Posts
Better off to be safe than sorry. I would run the net.
Mike Pearson 2485 SS |
#28 | |
2009 V/SA Record Holder |
#29 |
Not trying to jack this thread, but if the car has a cage that was previously cerified and is not required to have a cage do you still have to get it certified every 3 years?
4878 SS/GA 66CHEVY II |
#30 |
Liked 6 Times in 4 Posts
