Liked 16 Times in 5 Posts
About the carb question , if you use a 1975 or later Pontiac , you must use the 800 cfm q-jet .NHRA does not check carb no's, they just check the venturis and throttle bore sizes.Those carbs came on Pontiac, Olds and Cadillac and has a 1.218 primary venturi
