Old 12-19-2010, 02:03 PM   #1
Michael Pliska
Default Re: Reaction time
Are you using a foot-pedal switch to get the .250 RTs on the practice tree? From what I have seen, most people are slower with their foot than with a finger or thumb.
There are a ton of variables to vehicle reaction time, but basically if it starts moving forward with a minimum of body movement, then you are probably getting a decent vehicle RT.
My guess is that if you flicker the top bulb off you will be in the ballpark. If you turn off the top bulb, you are now 7" from turning off the stage bulb (clearing the beams) REGARDLESS of the front tire size. The shorter front tires just give you a shorter distance between turning the stage bulb on (dead shallow) and clearing the beams.
Michael Pliska 643 S/G
Michael Pliska is offline   Reply With Quote
