C11 is always available and I have never an issue at fuel check. Fattened up a little and mine runs quicker with it.
Ed Wright 4156 SS/JA |
Liked 165 Times in 59 Posts
just a fyi ,,once you have your combo put together and you have the option to dyno ,try different octane race fuels you might find some horse power ,,,, gmonde
Liked 54 Times in 27 Posts
Rockett 111 will have enough octane for a 1975 and work well. Oxygenated fuels aren't allowed like the Rockett 100. Some useful info is on their website:
http://www.rockettbrand.com/ If you run a stock gas tank, it would be best to seal it off during storage so volatiles won't evaporate, possibly causing you to fail fuel check. For example a non vented cap, and a shut off valve in the vent hose at the tank. |
Liked 13 Times in 8 Posts
Thanks Guy"s.Im leaning towards the Rockett 111.
Liked 20 Times in 12 Posts
Mike good advice. It was good talking to you at PRI and very informative. I will call David and try some CRF 110 this coming year. After what has happened with my fuel last year I am ready for a change.. Look forward to it. Thanks
Robert |
Mine is fuel injected. +5% @ WOT is what mine liked. Close to one MPH.
Iam located in Elkton Maryland,10 Minutes from Cecil County Dragway.
Liked 460 Times in 91 Posts
I have used Rockett 111 and VP-C12.........both are good but the Rockett was better. Hey sox Im in perryville and can hook you up with a good dealer............
Bob Bender 144 O/SA 2010-2012 National Record Holder |
I have met you before.I had the Showtime Wagon.I have talked to you and Bill Taylor at Cecil.I dont know if you are still looking for some 30x9 Slicks.I have a spare set that I got with the car.Goodyear radials with Low runs,also have a spare Hedworth Quadrajet.Let me know about the fuel.Looking to mix it up with the Big Boys this year.i hope I can hold my own..
#10 | |
