Old 12-08-2010, 11:38 AM   #11
Ed Wright
Ed Wright's Avatar
Default Re: New AHFS 2011
Adger, you have too many toys.
Ed Wright 4156 SS/JA
Old 12-08-2010, 09:20 PM   #12
jmantle
Liked 172 Times in 81 Posts
Jim,
We are not going to use all qualifying runs, which is why it reads “final qualifying runs and all elimination runs.” It’s no different than this year, or years past. With that said you are correct, what ever the is listed on the final qualifying sheet will be used in the review process.
Pat Cvengros
Technical Services Representative
In regards to Toby's question
Jim Mantle
div 6 S/SS
jmantle is offline   Reply With Quote
Old 12-08-2010, 09:34 PM   #13
Ed Wright
Ed Wright's Avatar
So, you hit the review trigger four times in qualifyimg, and only one of them counts?
Old 12-08-2010, 09:42 PM   #14
Toby Lang
Liked 2 Times in 1 Post
Thanks a lot, Jim. I was told last season that one person could get flagged twice during qualifying at the same race. Maybe I misunderstood or got the wrong info, but when I asked this same question in the other AHFS thread that Mike Crutchfield started he said:
Originally Posted by Mike Crutchfield View Post
And yes ALL runs count including all class runs and all LODRS runs. The wording can be a little confusing to me also.
I'm glad it's all cleared up now.
-Toby
Old 12-08-2010, 10:48 PM   #15
Bernie Cunningham
Liked 52 Times in 17 Posts
So, what if ?????
On one given weekend, at two different race tracks anywhere in the country, the same combo car (i.e. DP with same motor), which is two different cars with different drivers, go faster than 1.20 under to trigger an auto HP hit, does it get hit TWICE ??????
Bernie Cunningham 7053 STK
Bernie Cunningham is offline   Reply With Quote
Old 12-08-2010, 10:59 PM   #16
countrypuppy4865
countrypuppy4865's Avatar
Liked 228 Times in 70 Posts
Bernie,
Good Point if this would have been in effect DP 5.7 would have been rated at about 390 by the time it left Indy!
Jimmy "Cooter" Hidalgo, Jr.
4865 E/SA '04 GTO
4865 SS/GA '99 Firebird
Old 12-08-2010, 11:12 PM   #17
Mike Carr
Mike Carr's Avatar
Liked 83 Times in 37 Posts
Originally Posted by Bernie Cunningham View Post
So, what if ?????
Bernie, I believe the answer is "no". Last year, I believe Roy Johnson and someone in Division 4 (maybe Dempsey Pendarvis) both ran fast enough for automatic HP. I asked, and was told no, it only gets hit once. I would guess now, with the tiered HP hits, the fastest of the two runs would be used to hit the combination (i.e., if one car is -1.20 and another -1.40, the -1.40 penalty would be applied). I could be wrong.
Old 12-09-2010, 12:57 AM   #18
Bernie Cunningham
Mike, that's my exact problem with the current 'setup'. I know it happened last year and I have a hard time believing that it doesn't affect the AHFS twice !!!
Old 12-09-2010, 01:15 AM   #19
Mike Carr
Mike Carr's Avatar
True. I don't what, if any, amendments will be made for 2011.
Using my scenario of -1.20 and -1.40, last year, it would have received one hit, the standard 3.25% hit for ANY run, regardless of how quick. This year, -1.40 will receive a 7.25% hit. So in that sense, it would be better this year. IF they use a 'quickest run/most severe penalty' rule. Time will tell, I guess.
Old 12-09-2010, 06:17 AM   #20
Urraco
Originally Posted by Tom Moock View Post
New AHFS posted on NHRA site. Tom
http://www.nhra.com/competition/automatichp.aspx
Are they going to use the factored index, or the sea level index at the altitude factored tracks?
Urraco is offline   Reply With Quote
