Old 12-08-2010, 09:59 AM   #1
Dan Wilson
Default Re: new hp
A question to Jason.
The cam stayes the same lobe lift.
If the rocker ratio is increased from 1.60 to 1.65 will the valve lift
1. remain the same
2.decrease
3 increase
Dan
Dan Wilson, STK3171, K/SA
Dan Wilson is offline   Reply With Quote
Old 12-08-2010, 11:16 AM   #2
Chad Rhodes
Default Re: new hp
1. remain the same
2.decrease
3 increase
Dan
i know the answer, pick me!!!!!!!!
Chad Rhodes 2113 I/SA
Old 12-08-2010, 11:27 AM   #3
Jason
Liked 8 Times in 5 Posts
Default Re: new hp
1. remain the same
2.decrease
3 increase
Dan
A few questions for Dan.
The specs sent out for your engine in 19?? were what they were. Did the factory technican sending the specs back then know what your engine was built with? Would you like to have a new rocker arm ratio on your engine? If so just call the factory and see if you can get an increase on your engine's rocker arm ratio and cam lift.
I'm sure it would all be readily accepted!
Jason is offline   Reply With Quote
