Old 11-14-2010, 09:16 PM   #1
trikbag406
Question Cleaning lexan?
Hey folks,now that I've made and installed lexan windows in my Vega,what is the best way to clean and protect them? I've heard a lot of things,formula 409,Palmolive and water,but what do you guys use? Thanks-Lew.
Tranquility base,the Vega has landed...
trikbag406 is offline   Reply With Quote
Old 11-15-2010, 01:23 PM   #2
drgrcr1156
Liked 2 Times in 1 Post
Default Re: Cleaning lexan?
I use Plexus for routine cleaning. Jerry Bickel sells it but I have seen it in local hardware stores. Try those that sell plexiglass/lexan.
drgrcr1156 is offline   Reply With Quote
Old 11-16-2010, 08:39 AM   #3
SCOTT SST2871
Ditto!!
Scott fifield
SCOTT SST2871 is offline   Reply With Quote
Old 11-16-2010, 12:47 PM   #4
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Cleaning lexan?
A spray on plastic polish called 210 (or something like that) works well. Isoprophyl rubbing alcohol also seems to clean it and does a good job of removing shoe polish from the windows. It literally melts it and reduces the amount of rubbing required to get it off.
Old 11-20-2010, 09:34 PM   #5
trikbag406
Cool,thanks peoples,believe it or not,Amazon.com sells Plexus,and there's one of their locations about 5 miles from me.
Old 11-26-2010, 09:14 PM   #6
nickh
nickh's Avatar
Liked 654 Times in 196 Posts
Plexus is good and look at Novus had some good success with that as well
nickh is online now   Reply With Quote
Old 11-26-2010, 09:56 PM   #7
cad
cad's Avatar
Liked 93 Times in 52 Posts
You should be able to get Plexus at your local motorcycle dealerships.
CD
Old 11-27-2010, 06:51 AM   #8
nickh
nickh's Avatar
Jerry Bickel & Quarter Max sells the Plexus
Old 11-28-2010, 04:14 PM   #9
KEVIN T
Joy dishwashing det. and a soft cloth. Remember nothing that contains alcohol.
Kevin
KEVIN T is offline   Reply With Quote
