Liked 109 Times in 18 Posts
If your triple .000, one thou under giving up the stripe by one thou, what ARE the ways you can lose? My friend Bryan Sorce posted this on a forum yesterday and received some pretty interesting answers. So what do all of you think?
I'm guessing maybe you ran over the 1000' clocks
Chad Rhodes 2113 I/SA |
Locking up the brakes through the finish line with smoke involved!!! This seems to raise some concern with track officials.
Shawn Blair 6383 SS 634 STK |
Liked 70 Times in 22 Posts
Light at the scales or don't even stop or skip fuel check. Assuming a class car.
I keep reading the question looking for a trick but the best i figure your opponant is 002 under at best.
Stewart Way 2424 SS |
Liked 189 Times in 48 Posts
one thou under means you broke out- did you mean a thou over?
Angelo DiTocco '98 Firebird SS/HA '98 Firebird B/SA |
Angelo,
I meant a thou under. Re-read the question again. It can be confusing! My head hurt just writing it! Ryan |
Liked 564 Times in 66 Posts
Easy...he took to much stripe. While Bryan may have driven the strip, when you break out...you break out and lose. Unless the other guy breaks out by more. in this case the other driver may have had a .009 light and been dead on. for a .009 package. leaving Bryanonly .009 to work with.
To really tell the story you need both sides of the time slip. |
Re-read the question Bill. You're missing something. This wasn't an actual race. Just a question to get everyone thinking
Liked 774 Times in 164 Posts
The other car made a perfect run to beat you. Is the first one that I can come up with, maybe the only way. I am not counting any boundry or scale type issues.
Dave Casey 1330 STK |
Liked 779 Times in 209 Posts
If you went one thou under giving up the stripe by 1 thou. then your oppenent ran right on with a zero.
Or you crossed the center line to lose. |
