Liked 1,826 Times in 414 Posts
Before the new rule, you could be DQ'd for removing the damper, as the rule required the valve spring to be the same configuration as that listed in the blueprint specifications. So if you had an engine that required a 1.55" dual spring with damper, and you took the damper out, the spring configuration no longer matched the the blueprint specification. A tech man that was so inclined could DQ you.
Alan Roehrich 212A G/S |
Thanks Alan, but I guess it's a moot point now.
Bobby & Norene Zlatkin L/SA |
Liked 476 Times in 117 Posts
little easier for me, unfortunatley i (woody) just redid my heads...
but now can get rid of pile of shims and get behive springs... wont make any HP difference, my SMALL CARB & INTAKE are my RPM limiter not the springs jack and no they wont let me run the cheater 459 intake ?
Jack McCarthy 3609 STK "the Captain" |
