One the one hand it seems senseless to hash over this but on the other, my comparison to valve lift makes sense. Well at least to me...
If NHRA has a spec indicated in their books (deck height / rocker ratio) and in the end all they care about is a minimum volume between the top of the piston @ TDC & the chamber and a valve measurement @ maximum valve lift, then why publish the deck height or rocker ratio? My way of learning NHRA class racing engine blueprinting is if NHRA gives a spec, it is to be adhered too. Not "adjust according to what is convenient". Man, I've spent some money on OEM rods (before after market rod acceptability) adjusting the big end to obtain the exact deck height I desired. Now I'm wondering why NHRA publishes anything more that the throttle blade diameters on a carb. And if NHRA specs a positive deck (say a 383 mopar) and I run a negative deck instead, I can save on possible piston to head interference issues and I can probably run a tighter LSA for more power.
Jeff Lee 7494 D/S '70 AMX |
#2 | |
If you can't build in a little safety margin you are going to get tossed for stuff that won't help performance one bit.
Art Leong 2095 SS |
#3 | |
I'm at a loss to figure out how all those zero deck engines made it through tech for 35+ years before NHRA changed this rule. Guess those old engines did not have bearing wear or rod stretch? Still trying to figure out why a rocker ratio is so important when using this issue as a comparison.
#4 | |
It wasn't a problem as long as there was more clearance than less. Till I drove my car to Maple Grove, set the record with a motor that had never had a head removed. And had .034 to little deck height. Then curt leshure had a problem, and I had a bigger problem. As far as tolerance goes my motor had 134,000 miles on it was never out of the car (or had the head off) and it was .034 from the stock (listed) specs. And on some motors adjusting the rod length is not possible.
Art Leong 2095 SS Last edited by art leong; 11-14-2010 at 11:20 AM. |
Liked 880 Times in 311 Posts
This is the exact quote of the rule about deck height out of the 2006 NHRA Technical Policies & Procedures
I don't think it has changed any since 2006. . 1.2 ENGINE BLOCK 1.2a STOCK AND SUPER STOCK The deck dimension of the engine block can be either in or out of the block, provided that the difference in the compression is made up with the cylinder head gasket. Example: if the spec is for .002-inch deck and .020-inch gasket, and the actual measurement for the engine is .005-inch positive deck, then a gasket must be at least .027 inches. The opposite is true if the deck is below the block on an above the block spec, then the gasket may be thinner to the allowable total dimension.
Adger Smith (Former SS) |
