Old 11-08-2010, 08:00 PM   #11
Chris Williams
Chris Williams's Avatar
Default Re: What would be the min size truck to tow 24 foot enclosed?
Originally Posted by Tweaker View Post
would it be possible and safe to tow a 24 foot enclosed trailer with a F150? like a supercrew or something? they are just so much cheaper than f250's.
I wouldn't even consider it. It has more to do with weight, but I tow a 28' enclosed trailer with a GMC2500HD Diesel and it's the smallest truck I would use. Should've gotten the 3500 dually...
Chris Williams 6304 SC, TD, ET
Chris Williams is offline   Reply With Quote
Old 11-09-2010, 09:17 AM   #12
Tweaker
Tweaker's Avatar
Do you its possible for me to find a pretty good decent 250 or 2500 for $15 to 17$k?
most of the one's i see i can afford have 100,000 miles on them is that alright?
IHRA #2X41
http://khracing.projectrhyme.com
Tweaker is offline   Reply With Quote
Old 11-09-2010, 09:29 AM   #13
Tweaker
Tweaker's Avatar
Is it bad to get a gas motor in a 250 or 2500 ?
IHRA #2X41
Old 11-09-2010, 10:08 AM   #14
FED 387
Liked 333 Times in 180 Posts
100 thou on a 7.3 ford or a Cummings is nothing these engines will go 300thou easily if they have been/are taken care of STAY AWAY from the Ford 6.0 or 6.4 NOTHING BUT EXPENSIVE MAJOR PROBLEMS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! a V10 gas motor in a Ford is a good engine 5.4 is underpowered not enuf HP /torque there to move that weight-late model Dodge with a Hemi not too sure about most guys run the Cummins " The Duramax is a good engine but hard to find and pretty pricey if you find a truck with one in it-Its all about do you want to control the trailer or do ya want the trailer to control you"---You can use a 1/2 ton but it is not advisable brakes and suspension just cannot handle the load safely--Comp
Old 11-09-2010, 10:20 AM   #15
Tweaker
Tweaker's Avatar
What about the 250's or 2500's with a V8 Gas motor? finding the used v10's are not easy lol. what about the v6 cummins diesel's?
IHRA #2X41
Old 11-09-2010, 10:32 AM   #16
Tweaker
Tweaker's Avatar
reading on here a bunch of guys pulling 24 foot enclosed trailers with GMC or Chevy 1500's.
http://www.yellowbullet.com/forum/sh...closed+trailer
hmm ?
IHRA #2X41
Old 11-09-2010, 10:42 AM   #17
Tweaker
Tweaker's Avatar
what about the z71's?
IHRA #2X41
Old 11-09-2010, 11:20 AM   #18
jmcarter
jmcarter's Avatar
Cummings + Dually and you'll wonder why you considered anything else.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 11-09-2010, 11:27 AM   #19
Tweaker
Tweaker's Avatar
dont believe i can afford that 15k to 17k price range :P
IHRA #2X41
Old 11-09-2010, 12:16 PM   #20
Tweaker
Tweaker's Avatar
anyone hear good news about 2500 dodge ram w/ a hemi?
IHRA #2X41
