I wouldn't even consider it. It has more to do with weight, but I tow a 28' enclosed trailer with a GMC2500HD Diesel and it's the smallest truck I would use. Should've gotten the 3500 dually...
Chris Williams 6304 SC, TD, ET |
Do you its possible for me to find a pretty good decent 250 or 2500 for $15 to 17$k?
most of the one's i see i can afford have 100,000 miles on them is that alright? |
Is it bad to get a gas motor in a 250 or 2500 ?
Liked 334 Times in 181 Posts
100 thou on a 7.3 ford or a Cummings is nothing these engines will go 300thou easily if they have been/are taken care of STAY AWAY from the Ford 6.0 or 6.4 NOTHING BUT EXPENSIVE MAJOR PROBLEMS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! a V10 gas motor in a Ford is a good engine 5.4 is underpowered not enuf HP /torque there to move that weight-late model Dodge with a Hemi not too sure about most guys run the Cummins " The Duramax is a good engine but hard to find and pretty pricey if you find a truck with one in it-Its all about do you want to control the trailer or do ya want the trailer to control you"---You can use a 1/2 ton but it is not advisable brakes and suspension just cannot handle the load safely--Comp
What about the 250's or 2500's with a V8 Gas motor? finding the used v10's are not easy lol. what about the v6 cummins diesel's?
reading on here a bunch of guys pulling 24 foot enclosed trailers with GMC or Chevy 1500's.
http://www.yellowbullet.com/forum/sh...closed+trailer hmm ? |
what about the z71's?
Liked 229 Times in 99 Posts
I have the 2500 HD with the 8.1 L motor. It gets 11 mpg around town and 9 towing. I should have bought the diesel.
Floyd Staggs 787 SST |
I have an 04 Ford FX4 Screw with 18" wheels and it is only rated to pull an 8500# trailer. I believe it has the 2nd highest towing capability of all the F150s. Not a problem with my open trailer, +6000# loaded but sure throws a damper into getting an enclosed. Mind you that new 5.4 pulls like crazy, never down on power and I have no problem with brakes etc but do have a good controller and equalizer hitch. Have yet to use the bars or anti-sway link with this set-up
