Liked 667 Times in 201 Posts
Chris sent you a PM
Liked 244 Times in 26 Posts
What kind of MPG improvements should you see for a chip for this truck?
Liked 275 Times in 76 Posts
I get 19 with mine not towing, that is with it in mileage mode. I have 4.11 gears. I have been told I should get better than that, but I am turning 2100-2200 RPM at 75 MPH. If you get the RPM down to 1900-2000 I have been told that would help.
Sean
I wish someone would make one for the bigger trucks 550. I have a 4.88 rear gear and I'm at 2500 at 60 mph. And can't get any mileage 8 towing 12 or 13 not towing.
If I go real slow 50 mph I get 10 towing. But that's to slow for the interstate, at 60 a lot of prople wave their finger at me as they pass.
Art Leong 2095 SS |
Liked 54 Times in 27 Posts
Art, if you have a Cummins in your 550, call Mark at TST Products in Indiana. He worked as a Cummins engineer for 33 years and makes power/mileage products for those engines. 812-342-6741.
My truck has an F in front of the 550 with a 7.3 liter. I made a typo
Art Leong 2095 SS |
the main thing for mileage is similar to making power....more power, less throttle needed for mileage......make sure you have a CAI (cold air intake) and at least a full 4" mandrel bent exhaust.....I run K & N and Banks stuff.....I pull down around 24 mpg in my 2005 Cummins unloaded w/4.10 gears (2500)....go to the diesel forum sites and you can get unlimited info for darn near anything.....
www.cumminsforum.com hey Art....there is a LOT you can do with your F550.....just do a general word search for "powerstroke forum" lots of good info there.....also depending on your budget a Gear Vendors overdrive unit will definitely give you a mileage boost and pay for itself pretty quickly..... same for you Duramax guys...... Last edited by magnumv8; 11-09-2010 at 10:11 PM. Reason: more info |
