Old 10-26-2010, 04:08 PM   #1
novassdude
Liked 136 Times in 49 Posts
Default Re: 2011 Stock/Super Stock Rule Changes
Am I understanding this one correctly. You can not run heavier than the next lower classes Minimum weight? So there will be no more running 300 pounds heavy to slow down cars?
WEIGHT
All cars will be permitted to run on the class minimum weight, but may be no heavier
than the minimum for the next heavier class. Car can move up (lighter) one class or
down (heavier) one class. If weight is added, must be properly attached; see BALLAST.
Class and classification weight are determined without driver weight. Once classification
weight is calculated, 170 pounds is added for driver to arrive at total weight. All cars are
weighed with driver.
novassdude is offline   Reply With Quote
Old 10-26-2010, 09:49 PM   #2
Michael Beard
Michael Beard's Avatar
Liked 13 Times in 9 Posts
WEIGHT
HOLY COW! They actually did this?! I've been running that one up the flagpole for two years now! Good, common sense rule. -=applause!=- Thank you, NHRA!
Re: AAF/S.... uh, why don't they create some realistic weight breaks for the FWD classes instead of tacking onto the top? It's not like there are no letters in the alphabet past "E". While the "big cars" fight full-pound weight breaks because they'd have to "carry so much weight", what about the weight difference between DF/S and EF/S... 2,241 vs 2,895. 650LBS? SERIOUSLY?!
Old 10-27-2010, 08:54 PM   #3
GarysZ24
GarysZ24's Avatar
Liked 238 Times in 94 Posts
Thumbs down Re: 2011 Stock/Super Stock Rule Changes
I couldn't agree with you more Michael!!!
Gary Hampton
'86 Z24,173 V6
CF/S #5824 (#78 in 2021)
Old 10-27-2010, 09:28 PM   #4
Adger Smith
Liked 880 Times in 311 Posts
About the block rule: a NHRA approved aftermarket cylinder blocks" for s/ss
That is good news for the V-6 guys. Since GM has quit casting the Bowtie V-6 block there is a shortage. Brian Browell has stepped up and had blocks & heads cast and NHRA approved. That just about seals the deal on the new V-6 blocks for Comp through Stock. Since we can't count on GM or other MFG's to continue to supply parts I think it is the next step for NHRA to modify the rules to help us keep racing.
Adger Smith (Former SS)
Old 10-27-2010, 10:59 PM   #5
Barnstorm
Barnstorm's Avatar
Blossom digs out the old AT/SA Syclone and puts 30lb of boost in with an aftermarket alum block......
Old 10-27-2010, 11:55 PM   #6
Troy Henderson
Troy Henderson's Avatar
Liked 129 Times in 41 Posts
I'm waiting for that too!
Troy Henderson
Henderson Race Shop LLC 816-520-5389
www.hendersonraceshop.com
Troy Henderson is offline   Reply With Quote
