I have the 1-20 thread adapter fitting #6 AN, on my Q-Jet. Is there common practice to use 1-20 thread #8? If yes,is there a part number to order these fitting with #8 AN ?
Thank, |
Liked 110 Times in 29 Posts
Yes and use Russell # 640350
Liked 333 Times in 180 Posts
Jegs sells part #555- 100501 $9.99 for the -8 they also sell a -10 fitting go to the Jegs site put in the part number lots choices---Comp 387
By the way I believe it is a 7/8-20 size---Not a 1-20---Comp 387
Liked 13 Times in 7 Posts
Were you considering a # 10 to a Q-Jet fitting. If so contact John at Product Engineering and ask for PE 3510 -10 A.N. x Quadrajet. The cost is around $ 15.00 plus shipping. John can also custom design and make just about anything you can dream of.
#6 | |
Liked 49 Times in 15 Posts
A simple fix is to drill and tap your factory inlet housing to 3/8" pipe. With a good drill press and a sharp tap it won't take you more than 10 minutes. Then you can use a very common AN to pipe adapter.
Dean Feiock -- Stock 5002 |
Made mine. drilled and tapped the -6 fitting, thread in the -8. No problems
Jason M Silver NHRA Stock Eliminator - 1278 88 Oldsmobile Cutlass 307/213 Last edited by STOCK1278; 10-25-2010 at 06:40 AM. |
