Old 10-23-2010, 07:48 AM   #1
nhradave
Default Header options for SS/HA 350cu
Have car, need help with choices.I am unable to contact Davis. So step or not,if so ..who? Header plates, Stahl says 3/8 , some say 1/2 .
What are your thoughts?
1967 Camaro,295 hp. 350. 1.41, 60' weight 3200 runs 10.25s
Dave
nhradave is offline   Reply With Quote
Old 10-23-2010, 07:55 AM   #2
Mark Callanan
Liked 64 Times in 14 Posts
Default Re: Header options for SS/HA 350cu
Try Talking to Herb Gebler
(301) 937-4340
Mark Callanan 1027 STK
Mark Callanan is offline   Reply With Quote
Old 10-23-2010, 08:32 AM   #3
jmcarter
jmcarter's Avatar
Liked 3,240 Times in 986 Posts
Highly suggest contacting Mark Lelchook at Performance Welding. You can search other threads on his work...
http://perfweldheaders.com/
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 10-23-2010, 09:23 AM   #4
Liked 1,922 Times in 432 Posts
For a four into one header, Jere Stahl. For a four-two-one, Calvin Elston. Gebler and Performance Welding also make nice four into one headers, but for the price, I'd step up to Calvin Elston.
If you're on a tight budget, DynaTech makes a nice stepped four into one header.
Old 10-24-2010, 06:04 PM   #5
et7333
et7333's Avatar
I bought a set of the DynaTech headers and the tube lengths varied 12 inches so I returned them.
http://stevecoxracing.com
et7333 is offline   Reply With Quote
Old 10-25-2010, 02:39 PM   #6
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Thumbs up Re: Header options for SS/HA 350cu
Mike, I have a set from Mark and highly recommend them. They are a little pricey but you know what they say, you get what you pay for!
Old 10-26-2010, 12:46 PM   #7
Wade_Owens
Wade_Owens's Avatar
Liked 3 Times in 1 Post
X2 and 3!
Listen guys, do not spend 1 dime on ANY name brand header without at least talking to Mark Lelchook. If he can help, he will give you a price. You may have something that will work, he will tell you that also. Although the headers sizes, lengths etc are important, the collector on your combo may be more so.
Call him, you wont be sorry.......
Wade O
Old 10-29-2010, 03:17 PM   #8
nhradave
Thanks for all the input!!!
I was unaware of some of the fab. shops, these guys do great work.
Steve, the car has a set of Davis headers on it however they are very thin and patched.
Dave
Old 10-24-2010, 06:02 PM   #9
et7333
et7333's Avatar
Dave
What headers are you using now?
Old 10-25-2010, 02:17 PM   #10
Mike Pearson
Mike Pearson's Avatar
Liked 1,983 Times in 597 Posts
I have the same combo as you are running. Right now I have the off the shelf Hooker 17/8 striaght tube with 31/2 inch collector. I have run as fast as 10.02 at the current weight break in SS/HA. The header plates should come from your head guy and order the headers with the bolt pattern to match your plates. Mine are about 5/8 thick. The hooker headers are pretty equal in length. I had a set of Headman headers that were the same as the Dynatechs all different lengths. I did not see any difference in performance when I changed from the Headmans to the Hookers.
Mike Pearson 2485 SS
