Old 10-01-2010, 07:29 PM   #1
jeff coyne
Question moroso front springs?
time for some new front springs. i would like to know should you go by only the front weight or do you use the part number for your car and cut to adjust?..
some say just use the part number and let is sit...last time it never settled..had to remove 3/4 of a coil...whats say you's? tks for your time jeff
jeff coyne is offline   Reply With Quote
Old 10-01-2010, 07:48 PM   #2
Doug Blackley
Doug Blackley's Avatar
Default Re: moroso front springs?
Jeff cut 1 coil off the Morosos and it'll sit right.
Doug Blackley 1697 STK
Old 10-01-2010, 09:18 PM   #3
Bill Bogues
Bill Bogues's Avatar
Liked 169 Times in 53 Posts
Smile Re: moroso front springs?
Jeff: I just got a new set of the Moroso front springs for my Nova71 SB car) . I ordered them by the front end weight of the car. Drivers side was just right; passengers side needed a 1/4 coil cut off. The stance of the car really depends on how much rear preload, if any, you run on your car. Hope this helps.
Bill Bogues 4696 STK
Bill Bogues is offline   Reply With Quote
Old 10-01-2010, 10:14 PM   #4
72Malibu
72Malibu's Avatar
Don't cut them, if anything get a lighter spring and use spacers to get ride height. Thats what the guys at www.santhuffshocks.com say
*** 72 Malibu ***
1.329-3.99-6.28@106.71-9.98@131
best 60ft to date-1.2997
72Malibu is offline   Reply With Quote
Old 10-02-2010, 02:36 PM   #5
REGGIE WINKLES
Liked 39 Times in 9 Posts
Like doug says, one coil on the moroso springs for the 3rd gen cars.
Reggie Winkles 2650/Stock
REGGIE WINKLES is online now   Reply With Quote
