Just wondering how much air pressure to run in a 30x9 hoosier lightweight drag slick on a 10 inch rim.Car is a 2800 pound fox body Mustang auto?
Liked 138 Times in 51 Posts
I run 21 lbs in those same Hoosier slicks on 10" rims (94" circ.). My car weighs 3,540 +, but most people I've talked to are between high teens and low 20's. Lots of variables between vehicles, but that should give you a starting range.
It will be interesting to see if anyone is much lower or higher, especially in lighter cars. |
I run 22 lbs on good track and no less than 18lbs. If it doesn't hook with 18lbs then I make a shock adjustment. Same tire and weight as Myron. Jim
Jim Wahl....NHRA #2239 S/SS - IHRA # 8 Stock, D2 Stock Champion (forever I guess) 2019 Baby Gators Stock Champion 2009 NHRA D2 National Open Stock Champion 1982 NHRA D2 West Palm Beach LDRS SS Runner Up Past President, Southern Stock / Super Stock Association. ![]() |
Liked 5 Times in 3 Posts
I run 20lbs on a "not so good" track & 25lbs on a good track
Liked 6 Times in 4 Posts
19-21 lb......
3100 lbs 1987 camaro I run 28- 30 lbs. hooks 99.9%
Liked 223 Times in 73 Posts
I have run as high as 26psi with out a problem my car does not have alot of power. Fox body at 2965lbs low 1.60 sixty foots 1.59 twice 5.0 stocker
22-25 in 3700 wagon....1.52/60 19-22 in 3300 Demon 1.36/60 Both calvert springs and nearly 50/50 weight.
Liked 165 Times in 59 Posts
ran them at 24 psi on a good track 3660 lbs car,,check the track for bald spots and stay out them !!!!! gmonde
Liked 39 Times in 5 Posts
30-36 in a 3600# L/SA wagon
Norm Webber |
