Old 09-12-2010, 11:52 PM   #1
junior barns
Liked 20 Times in 14 Posts
Default hood clearance
how much hood clearance should there be and where to measure from off the carb??
junior barns is offline   Reply With Quote
Old 09-13-2010, 01:05 AM   #2
SSDiv6
Default Re: hood clearance
Assuming the vent tube is the highest point in the carburetor, measure from the vent tube to the hood. Minimum from vent tube to hood 2.5".
Old 09-13-2010, 12:39 PM   #3
junior barns
Thanks a bunch !!
Old 09-13-2010, 03:44 PM   #4
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: hood clearance
The more, the better. But I have less than 1.5" with no apparent issues and that's with the air cleaner assembly removed! FWIW, I recently browsed through a book by Smokey Yunick and 3/4" was mentioned as being the absolute minimum. Don't know if some carb's are more sensitive than others. I have a Holley. Underhood airflow/turbulence may have an affect with a aircleaner baseplate being helpful.
Old 09-13-2010, 04:54 PM   #5
SSDiv6
With early cars that have a lot of reinforcement under the hood, you can go with less. Later model hoods, and/or fiberglass hoods, can bow at high speeds reducing the clearance.
Old 09-13-2010, 07:34 PM   #6
Jeff Lee
Jeff Lee's Avatar
Oh, is that what it is. I always thought my ultra-powerful engine was sucking the hood in...
Jeff Lee 7494 D/S '70 AMX
Old 09-13-2010, 08:34 PM   #7
art leong
I have about 2 feet LOL.
Hood scoop is of no use, air intake is out the bottom.
Art Leong 2095 SS
Old 09-13-2010, 09:26 PM   #8
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 316 Times in 107 Posts
Art,
do you put flat hood for heads up or record runs?
So with that scoop do get asked if that things got a hemi?
Mike Taylor 3601
Old 09-13-2010, 09:57 PM   #9
art leong
Originally Posted by Mike Taylor 3601 View Post
Art,
Mike Taylor 3601
I have a flat hood, and some steel fenders ready to paint.
I predict I'll pickup half a second. Bring on the DP's and CJ's
Art Leong 2095 SS
