I am going to have my block bored, it's standard now, and wondered how much et I will sacrifice if I go .030 instead of .060. Anyone race a stocker with the .030 block then later punch out to .060? Was there a substantial gain? I don't know if there is much power in 5 extra cubic inches. Block could be used so much longer this way. Thanks in advance for any info provided.
Jesse Knapp 4899 STK, SS |
On the great big assumption that going bigger doesn't compromise ring seal,
and if your building a Stocker that should be able to make at least 1.25 HP per CID, then you have to ask yourself is 6.25 HP worth anything to you? Someday that extra .05- in ET may come in handy.
Jeff Lee 7494 D/S '70 AMX |
Liked 5 Times in 3 Posts
& think if you offset grind the crank even more inches
This engine would fit a class where the dp cars dominate. That's why the question. Thanks for the replies.
#6 | |
Not sure how you would plumb around the water jackets but anything is possible! ![]()
#7 | |
Liked 10 Times in 7 Posts
Liked 53 Times in 17 Posts
I run a low compression 350 and I can tell you that ever cubic inches is worth about 1 hp
or better and all my engines are 60 over plus So the more inches the better (that is from a pro engine shop) |
Liked 99 Times in 49 Posts
Jesse if its a stock block i would stay at 030 ,if you have a bow tie then 060 the st blk will likley make more power at 030 due to cly walls are not thick enough. Jim Hanig my 2 cents
