Old 09-08-2010, 04:06 PM   #1
Mike Pearson
Mike Pearson's Avatar
Liked 1,954 Times in 590 Posts
Default Re: fish tailing
Is your truck a dually? if not your tires are probably overloaded with a trailer that long.
Mike Pearson 2485 SS
Old 09-09-2010, 04:12 PM   #2
Tom Simon
I've put thousands of miles on my similar combination, 32ft tripple axle tag behind a 1 ton crew cab dually... it wasn't bad, but things got a lot better, particularly in the Mojave crosswinds on the way to Vegas, after I added a single Reese friction-type sway control. Much like a shock absorber on all four corners of any car or truck, sway control devices damp out sway between the truck and trailer.
I latter towed the same 32ft tag trailer behind our 1 ton 15 passenger Ford van... the sway came back. For $60, I simply added a second Reese friction-type sway device, and the problem went away!
I'm a believer... "your results may vary"
Tom Simon is offline   Reply With Quote
