Liked 100 Times in 45 Posts
Is the back of the truck level or down like it's over loaded?I tow a small (18') but heavy
(almost 7K) with a Dakota with a 5.2.I have an air bag setup on the rear springs,and load bars.Truck sits level,trailer a tad higher in front than back and other than huffing in the hills it tows fine.Don't ask me about stopping briskly.
Former NHRA #1945 Former IHRA #1945 T/SA |
I have a 34 ft tag with full living quarters and 22 ft garage for my camaro.It's also a triple axle and I had a similiar problem until I installed the EQUALIZER HITCH.Here is the link:
http://equalizerhitch.com/ Well worth the $575 dollers.No wind proplems,or when Big trucks pass. |
Liked 1,926 Times in 579 Posts
Is your truck a dually? if not your tires are probably overloaded with a trailer that long.
Mike Pearson 2485 SS |
I've put thousands of miles on my similar combination, 32ft tripple axle tag behind a 1 ton crew cab dually... it wasn't bad, but things got a lot better, particularly in the Mojave crosswinds on the way to Vegas, after I added a single Reese friction-type sway control. Much like a shock absorber on all four corners of any car or truck, sway control devices damp out sway between the truck and trailer.
I latter towed the same 32ft tag trailer behind our 1 ton 15 passenger Ford van... the sway came back. For $60, I simply added a second Reese friction-type sway device, and the problem went away! I'm a believer... "your results may vary" |
