Old 09-02-2010, 02:25 PM   #1
Bench Racer
Liked 99 Times in 21 Posts
Default Re: higher staging rpm stall speed= reduction in R/T
I was chatting with someone at the ATI trailer about converters a couple of years ago. I asked about staging RPM's having any effect on the performance of a superstock combo. If I understood him correctly he stated that if a converter was set to flash 5200 with your combination it will do it if you stage at 2500 or 4500. This did not take into account an issue with a carb that that has not had the accelerator pump set up properly and stumbles when you nail it at low RPM. He also said many times a car will be quicker if you "hit" the converter from a low RPM vs max stall, but different stage RPM's will alter your reaction times. Don Jackson
Bench Racer is offline   Reply With Quote
