i have been around bracket racing for about five years now and now i want to take it up a notch and try class racing
my first question is i have a 65 chevy ii and what is mandatory for the interior |
Liked 5 Times in 3 Posts
Heater controls, head liner, carpet(or rubber mat), front seats, door panels, dash & dash pad. (this is just off the top of my head)
Liked 1,784 Times in 407 Posts
Pretty much everything must be stock and remain in place except the back seat, which may be removed if a roll cage is installed. The back seat area would then have to be replaced with a firewall and covered in some sort of upholstery. You can add aftermarket gauges, a shifter, and a steering wheel.
You need to go here: http://www.nhra.com/competition/classification.aspx That will let you know which engine/transmission combinations are legal in your car. Just scroll down to the "Chevrolet" section and click on "1965". You'll find everything from a 153 4 cylinder at 90HP, to a 327/300HP V8 at 265HP. Then go to: http://www.nhra.com/competition/blueprints.aspx That gets you the engine blueprint specifications for the engine you want to use. Again, scroll down to the "Chevrolet" section and click on "1965". You'll find all the necessary specifications in the engines there, including casting numbers for heads and intakes. You'll need Excel, or Excel reader to read the classification guide, and Word to read the blueprint guide. At the top of those pages, there is a menu that you can scroll over that is entitled "Competition", there you'll find legal replacement pistons, rods, and other parts. You also need a printed copy of the rule book. Welcome to the asylum, and good luck.
Alan Roehrich 212A G/S |
Liked 69 Times in 30 Posts
I'm also building a stock eliminator 87 Camaro or maybe buying one but my question is similar but Greg you've stated that the heater lever have to be there also, even though all the heater and air conditioning evaporator have been removed?is it for looks only? Thanks
I don't know the exact reason for it, but yes, you must have the controls in place.
Probably to stop them from looking like swiss cheese cars, since I've already started to remove all wiring harness, I hope that lights don't have to be working? thanks for the help.
The rulebook does not show a requirement for dashboard lights of any sort. Of course, you'll want lighted gauges. They only require one headlight and one taillight.
