Old 08-02-2010, 07:40 PM   #1
Rob Lloyd
Default Re: Turbo Stockers
Originally Posted by art leong View Post
It happened to me a few times especially when the car sat for a couple of months. I would just free it up. Then put it back together.
It happened when I sold the car to Jim. Took it to Cecil County Went to the line, The car left like a garbage truck. I knew what the problem was but the look on Jims face was priceless I knew he was thinking what did I come up here for? Loosened it up, ran the expected number. And the car was on it's way to Fla.
If I were you I'd look for some heat resistant preoiled bushing And install that.
It seems to be the leaded gas that does it Jimmy Malone hasn't had it happen to him that I know of and he uses the VP unleaded.
I suspected the leaded fuel might have something to do with it.
How did you free them up?
Rob Lloyd 3728 BF/S
Rob Lloyd is offline   Reply With Quote
Old 08-03-2010, 09:40 AM   #2
art leong
With a hammer (chevy tool).
Art Leong 2095 SS
Old 08-03-2010, 10:07 AM   #3
Jimi B
Just ditch it and run an external wastegate ha.
Jimi B is offline   Reply With Quote
Old 08-03-2010, 12:13 PM   #4
Rob Lloyd
The legality of that seems a little gray to me, so I think I'll stay away from them until it's more black and white.
Rob Lloyd 3728 BF/S
Old 08-03-2010, 12:49 PM   #5
I suppose all of this applies to FWD cars where traction is a problem.
You won't melt stuff if you retard the timing appropriately.
Why not use an MSD Boost control?
Old 08-03-2010, 09:39 PM   #6
art leong
Mark I can show you 20 turbo dodges with stock type ECU's that slowed up a bunch with the MSD unit.
If you retard timing you actually raise EGT I know it doesn't make sense. But I've been there done that.
Art Leong 2095 SS
Old 12-18-2010, 06:06 PM   #7
bad440
bad440's Avatar
Unplug the knock sensor it will be more consistant.or the ecu will hear noise and retard the timing a bunch.would love to check out a 2.3 turbo stocker.
bad440 is offline   Reply With Quote
