Liked 880 Times in 311 Posts
I got curious because I had a 68 GTS with a 383 back in the early 70's.
We used it to tow our Z-28 for a while until we got a truck. I put fenderwell headers on it and it made it a different ride!! Really picked up the power over the restrictive ex manifolds. I noticed a few '73 340's (rated 293) in Nitro Joe's stats that were in G/SA and running pretty good. The lone 383 was about half way down the list. I looked at the class guide and the 340 is listed @ 10.92 and the 383 @ 11.08. That makes the weight just a few pounds different. Wouldn't it be easier to move the 383 up and down in classes and it have an advantage? Fit in 3 classes and the 340 in just 2??? It might be slightly under rated at 295 vs the 299 NHRA HP for the 340. Small carb seems to be the only bad thing about it. After looking at the blueprint specs I might consider the 340--- .5 more compression (didn't figure the actual, just used the listed) about .030 more lift on both the in and ex. similar valve sizes and a piston with a notch for valve clearance as well as a better spring design (W damper). Same carb size...Did notice one of the good casting #'s for the 383 head..... Humm!! I have no experience with either engine as a stocker, but the specs would have me leaning toward the 340. This might be one of those toss ups.... What you mopar guys say?
Adger Smith (Former SS) Last edited by Adger Smith; 07-30-2010 at 08:29 AM. Reason: sp |
