Old 07-17-2010, 05:56 PM   #21
Woodro Josey
Liked 3 Times in 1 Post
Default Re: A case for aftermarket seats in stock
Let me clear this up right now, i could care less where NHRA lets you use an aftermarket seat or not. When i was on the the SRAC committee, i recieved a lot of letters asking for the seats and we forwarded it to the NHRA Committee and they turned it down. Now as for the 5 HP, i don't remember NHRA giving SuperStock Horsepower when they started allowing the seats. I took my ride on a head on collision and my seat held up, but there are some cars that the seat will not! Just like Presidents, some of you vote one way, some of you vote another!
Woodro Josey 2002 STK
Woodro Josey is offline   Reply With Quote
Old 07-17-2010, 06:00 PM   #22
Chad Rhodes
so Dave, did you take your 5 hp hit for wheelie bars, for aftermarket brakes, etc.? Maybe they should give you 5 hp off for having a cage, since you would add weight for that, and it would be toward the front.
Chad Rhodes 2113 I/SA
Old 07-17-2010, 06:50 PM   #23
Jeff Goss
Jeff Goss's Avatar
Smile Re: A case for aftermarket seats in stock
They allow the seats, but you must have a cage if you put them in. In my case, it's up to me to add the weight of a cage vs. the weight reduction of the seats. Seems like a wash in my case,.
Jeff Goss is offline   Reply With Quote
Old 07-17-2010, 07:44 PM   #24
Dave Ficacci
Dave Ficacci's Avatar
Liked 98 Times in 23 Posts
No, but if they did, I would take them out. That's my point. I also don't follow your logic about how ADDING weight against the roof line for the cage in the interest of safety applies. That is probably the worst place in a racecar to add weight.
I like how you ignored my questions about the safety items. I'm guessing you fall into the group that runs NONE of those safety items..further proving my point that you want this enhancement for others reason than safety.
Dave Ficacci
1013 STK
1170 SS
Dave Ficacci is offline   Reply With Quote
Old 07-17-2010, 08:28 PM   #25
Tony Janes
I would say that Kirkey seats in a 69 camaro would save about 65 pounds. The question would be how much can one put in the trunk? The seats will make the car lighter even with the addition of the roll cage. Stock today is nothing more more than Super Stock with 9 inch tires, stock manifolds and stock lift cams. I think that Stock should have the same rules as Super Stock. Any rear end, transmission optional, roller rockers. None of this adds horsepower to the engine. In the case of the three speed vs a powerglide, it will make the car work better. in most cases. The big threat in stock today are drag paks and mustangs. Will NHRA do any of the above, probably not. While we are at this, lets add the 1955 to 1959 Chevys to stock.
Tony Janes 7941 STK, SS
Old 07-17-2010, 09:15 PM   #26
Bob Don
Bob Don's Avatar
Liked 905 Times in 193 Posts
This is probably an unpopular stance, but changing the seat rule would just be one more step in making stock less stock. I realize there have been a number of rule changes over the years that have taken stock further and further from where it began but where do you draw the line? You all built your cars for STOCK eliminator. If you want to do more mods, consider going to a different category where those mods are allowed. Tony James is right, stock has become a glorified super stock but I think it should try to remain true to its origins.
Bob Don 128 SS
Old 07-17-2010, 10:58 PM   #27
I don't really care one way or the other how much money you want to dump into those cars.
I'd vote NO, just because of the way some of the fast guys treated the Deep Staging issue .
See how that works, guys?
Old 07-17-2010, 11:41 PM   #28
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Wink Re: A case for aftermarket seats in stock
A very interesting statement. Jim
Old 07-18-2010, 01:42 AM   #29
Chad Rhodes
I'll address your safety issues. Clothing, I wear everything but gloves. The A/SA car will get the cage and window net over the winter, not so much for the newly acquired I/SA, there is a full trans shield on the Vette, no diaper yet, but I'm not sold on those yet. I have very expensive full face helmet, however on a stock seat a HANS is mush less effective due to lack of a good headrest, according to a HANS rep at PRI.
As for another motive, sure I'd love to get my head lower in the vette, it's a tight squeeze. But the weight would be no advantage as we already run weight on the nose and have to run a second battery and 40lbs of lead to make even AA/SA. What's your reason for being so against race seats in a stocker???? Got a fortune tied up in a pair of Swiss cheesed lightened stock seats?
Old 07-18-2010, 04:58 AM   #30
Evan Smith
Liked 115 Times in 5 Posts
Since the HANS prevents overextending the neck and head in an impact where your body goes forward (in most cases), why does the headrest in the seat matter?
As for seats, the stock seat in my Mustang, a vehicle built in the 1990s, has slop in it and I would be safer in a properly designed racing seat.
Most of the non-racing aftermarket replacement seats are not held to the same factory crash standards and would likely be no safer than a stock seat, even an old one. In fact they could be worse, despite being seemingly sturdy. Most stock seats have lots of bracing in the back area, in order to hold up in a crash, or severe back injury will result. I have actually spoken with Ford vehicle engineers about this in the past. There are, however, lots of good aftermarket drag racing and road racing seats on the market. A solution could be to run a factory seat from a later-model vehicle. Then you don't have to worry (as much) about a weight issue. Surely, a seat from a 2010 Camaro, Mustang or Dodge will be plenty safe.
I started wearing gloves when the pants rule was put in place. I felt that I should apply logic because ironically, you don't need fire protection on what to me is the two most important areas of your body—your face and hands. In the case of a fire, I want to protect my face (I wear a full face with shield down) and my hands. Most of us need our hands to make a living, so why wear a jacket, pants, helmet, and no gloves? I just made it part of my routine and it's no big deal. It took me about 10 runs to get comfortable with them. I also have an on-board fire system.
I agree with Greg in that perhaps we should look at seats because many cars are old and have potentially worn-out seats, tracks, hardware, etc., but those seriously interested in safety should also follow Dave's advise and first get everything allowed to protect yourself.
Evan
Evan Smith 1798 STK
Evan Smith is offline   Reply With Quote
