Old 07-13-2010, 10:58 PM   #1
doglover44
doglover44's Avatar
Liked 498 Times in 235 Posts
Default Column Shifters
What is the rule for auto shifters on the column are they allowed ?
Jake Biermann
Old 07-13-2010, 11:55 PM   #2
rick lester
Liked 4 Times in 1 Post
Default Re: Column Shifters
I am assuming your asking about column shifter for an automatic trans. In the 2010 NHRA rulebook, nothing is mentioned about "no column shifter allowed" so I would assume it is legal. I used a column shifter in my low 12 second street car back in the late 80"s so it is doable. Alot of street racers use a column shifter for that "sleeper" look. A manual transmission are allowed to convert to a floor shifter. With a few exceptions, the IHRA and the NHRA rulebooks are the same. If you don't have a NHRA rulebook, you can down the IHRA rulebook directly from their site.
Depending on what your planning on running, some combos with headers won't work with a column shifter. Other than Mopars, full size GM and Ford cars, anything with a big block would need a floor shifter.
rick lester is offline   Reply With Quote
Old 07-13-2010, 11:59 PM   #3
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
How about that pesky positive reverse lock out thing???????????????/
Bob Mulry 7516 STK
A & M Motorsports
Old 07-14-2010, 12:15 AM   #4
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Thumbs up Re: Column Shifters
when I started running stock I had my P/G set up with a rev valve body just so I could use the factory column shifter.....yank down 1 time! real easy!
Old 07-14-2010, 01:04 AM   #5
Bob, The reverse lockout deal doesn't pertain to OEM shifters.
When I converted my Chevy II to a PG, I just bought $20 worth of column shift parts from a guy and the reworked the detents for the manual ,forward 1-2 shift .
Easy enough to do with fender well headers.
